Sew rectifiers
Sew rectifiers
Sew rectifiers
Greetings to all,
     I'm just new here, and I would like to ask if what are the main causes on why do SEW bge 1.5 rectifiers to go bad, together with its brake coil? Thank you.
 Best regards,
RE: Sew rectifiers
I believe the brake coil will draw excessive current if the brake plate can't seat correctly.  That either burns the coil out or the diodes.
Keith Cress
RE: Sew rectifiers
Or you have applied the wrong voltage to the brake coil. Happens a lot when people retrofit VFDs or soft starters without separating the brake coil circuit.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
