DESIGN OF UNDER GROUND WATER TANK
Dear All
I am design an underground water tank of 35mx15mx3m deep.Since the tank plan size is big i have introduced columns in 5m grid in both directions. I have modeled and analysed with finite elements of size 0.5mx0.5m. Designed as per IS:3370 ( Indian Code )for uncracked
section. Columns are modeled with members. All other check for stability and flotation were carried out as per standard methods. Please comment and suggest me if any mistakes in the above concept.
best regards
MVV
RE: DESIGN OF UNDER GROUND WATER TANK
Finally, because it's large in plan, you really need to check for earthquake with hydrodynamic forces.
