API C# STARTING PROBLEM
Hi
I'm new in SolidWorks API programing.I'm working in C# programing language. I made some programs and this programs work well. But I have a problem with a programs example from SolidWorks API HELP. I copy the program code from HELP and paste it in SolidWorks API editor. When I run this program there are four mistakes:
1. Error 1 'Macro1.csproj.SolidWorksMacro' does not contain a definition for 'swApp'
2.Error 2 The name 'Main' does not exist in the current context
3.Error 3 'Macro1.csproj.SolidWorksMacro' does not contain a definition for 'swApp'
4.Error 4 The name 'Main' does not exist in the current context
Please help me how can I fix this problem
RE: API C# STARTING PROBLEM
I solved this problem, but I have the new one.
Please sameone write the short program in C# which it will open the file C:\model.sldprt.
I don't know how can I use OpenDoc6, because the examples for open document from API Help don,t work.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Option Explicit
Dim swApp As SldWorks.SldWorks
Dim Part As ModelDoc2
Dim Measure As Measure
Dim boolstatus As Boolean
Sub main()
Set swApp = Application.SldWorks
Set Part = swApp.ActiveDoc
Set Measure = Part.Extension.CreateMeasure
Debug.Print "Distance: " & Measure.Distance
End Sub
That would be very helpful for me.
TOP
CSWP, BSSE
But you can't record above program.
This above program get the distance between two selected entities (in VBA).
I don't know how this get in C#. But I realy need this data in C#.
Please help me.
