Economical Pilot-Scale Centrifuge Suggestion?
Need to separate polyelectrolyte from water in a pilot plant in continuous (or semi-continuous) mode.
Lab tests indicate separation at ~5500G is sufficient.
Inlet flow rate capacity of the unit can be anywhere from 0.5-5L/min.
Solids content in the inlet solution is ~0.5%
"Solid" phase will be a bit viscous / gell-like after centrifugation.
Space constrained (due to doors),
Electricity (110 or 208VAC 1PH)
Budget is extremely limited.
I have checked the used market, but have found nothing quite right so-far.
Any suggestions.
Any suggestions.
RE: Economical Pilot-Scale Centrifuge Suggestion?
