#delete all
#delete all
#delete all
Can someone explain what exactly is happening when this command is used in I-deas? I was given this command from a colleague to fix an issue when the import command started to have issues with file strings.
RE: #delete all
It deleted all entities on the screen.  Occasionally there are entities that are left on the screen that can not be selected and end up causing issues.
