untrim axis in drawings
figure this out: you trim in several points an axis for a shaft and repent doing it. There is no way to go back. If you erase the axis it gets listed again in the "Show model annotations" tab and you can select it again. But it's still trimmed where you had truncated it. Extending and playing with handles on the extremities does not work, too.
How to do?
Pro/E wf5 (Creo Elements)
How to do?
RE: untrim axis in drawings
Forgive me for the useless post.
Yes, sometimes learning new versions of software, I overlook the obvious.
