MIRROR DISPLAY
MIRROR DISPLAY
MIRROR DISPLAY WILL NOT SHOW MIRRORED BLOCK THAT ISNT ON THE SCREEN. WE DESIGN MANY "MIRRORABLE PANELS" AND MIRROR DISPLAY HELPS KEEP THINGS VISUALY LINED UP FROM SIDE TO SIDE. IN NX3 IT DIDNT MATTER IF THE BLOCK WAS VISABLE OR NOT...IT MIRRORED IT'S DISPLY.
RE: MIRROR DISPLAY
Thank you.
As for your problem, it's not a matter of whether it's being displayed as much as whether the other bodies are INSIDE the 'clipping planes'. Try going to...
View -> Camera -> Edit...
...and near the bottom of the dialog in the section titled 'Clipping', select the button labeled 'Fit Planes to Extents' and then hit OK. Now check to see if that resolves your problem.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
RE: MIRROR DISPLAY
DRAW A BLOCK ABOVE Y=0. IF YOU ZOOM OUT AND CLICK MIRROR DISPLAY IT SHOWS BOTH BLOCKS. IF YOU ZOOM IN ON THE MIRRORED BLOCK, FAR ENOUGH TO TAKE THE SOLID BLOCK OUT OF THE PICTURE, THE MIRROR BLOCK WILL DISAPEAR. IN NX3 IT STAYED VISABLE NO MATTER WHAT.
RE: MIRROR DISPLAY
Now as to your OTHER PROBLEM, please turn OFF 'Caps Lock'!!!!
If you continue to type in UPPERCASE, it will be precieved as if you're SHOUTING at the audience and eventually people will ignore you altogether.
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: MIRROR DISPLAY
RE: MIRROR DISPLAY
John R. Baker, P.E.
Industry Sector
Cypress, CA
RE: MIRROR DISPLAY
And please, why are you still replying with your 'Caps Lock' ON?
John R. Baker, P.E.
Industry Sector
Cypress, CA
