Why is a steam pressurized vessel more dangerous?
Could someone please explain why a pressure vessel filled with saturated steam at 150 psi would be much more dangerous than the same sized vessel filled with air at 150 psi, if it were to explode due to fracture? I am interested in an answer based on stored energy and I am guessing the key thing here would be the latent heat in the steam but how would this contribute more explosive power?
Thanks for anyone's help!
RE: Why is a steam pressurized vessel more dangerous?
Sam epressure, right?
But with steam you have higher temperature, so you have lower strength in the metals resisting the same force.
You have burns to worry about, plus condensation and expansion forces as the vessel is being filled. If a air-filled vessel vents (breaks open), it releases its energy, nothing's left. But the boiler will keep boiling off water as long as its pipes and walls and thermal mass is hot. (We have to keep turbines turning for dozens of hours after the steam is shut off to remove residual heat and prevent damage from bowing and loss of lube oil to the bearings. Lots of other "little" things like that.)
Most important, after failure of a steam system, the metal and pipes is still hot, still burning people and things.
Corrosion at high temps, chemical deposits, condensation and water traps and water hammer, thermal movement of the original container & Movement of pipes and restraints cause more design problems -> More likely design errors and stress risers, so failure is "easier" to get, harder to prevent in a steam system. .
Also, there would be an associated drop in pressure in the boiler supplying the steam and as the pipework connecting the boiler to the pressure vessel would be open, the water in the boiler would flash off to steam causing a rapid expansion of additional steam through the pipework and into the exploding pressure vessel? Is this correct?
Any condensate initially in the vessel would also flash off to steam, causing more expansion?
rmw
PS: when you asked your original question, it was a PV filled with saturated steam vs. air. In a later post, you mentioned water in the boiler flashing off. If this a PV or a boiler?
What changed?
Whoever said that, ask them which they would prefer to stand next to during a pressure test...
Visitng a Hx fabricator recently, when I asked him about air testing a large vessel (at a fairly low pressure - about half of 100 PSIG) and his views on air testing, he recounted an interesting story. Said he had to air test a Hx or vessel to 600 PSIG. He stated that he installed a large faced pressure gage on the vessel and monitored it through binoculars.
rmw
Cheers,
gr2vessels
radio1julie,
You mentioned pressure test. Are you considering a pressure test with saturated steam as the medium?
Normally and preferably, pressure test is done with water. Water is almost incompressible so it stores less energy. If a hydrostatic test is not possible, then you consider other types of pressure test like a pneumatic test (air). But a pressure test with saturated steam, this one I've got to hear.
Let's say a pressure test with saturated steam is acceptable by your local boiler authority, you need to make sure that your boiler is designed for external pressure. This is in case the steam condenses.
As steam is the obviously convenient medium with which to pressure test these dryers (as and when this is required by local authorities and for whatever reason), then steam is what is used. However, from time to time one of these dryers may need to be tested in storage where steam is not available as it is not mounted, and piped up, in a paper machine. In this case, a conventional hydro test can be set up using water. However, from time to time people have suggested using air and this is when people have suggested, and in my opinion wrongly, during discussion that air is even more dangerous than steam if an explosion was to occur?? There HAVE been occasions when a dryer has been sat in a mill yard far from any water supplies and it has been suggested to use a portable air compressor to pressurize one of these dryers. This is where the arguments start. I just want to point out, and have the arguments/calculations to support this, that air is no more and possibly less dangerous than steam??
Okay now I understand what your equipment is. It is a pressure vessel with steam supplied to it by a boiler. Sorry I misread your previous post about it.
I've never heard of a pressure test with steam before. Like I said normally it's a hydrostatic test or else it is a pneumatic test. Have you considered acoustic emissions test?
This paper seems to tell some stuff about an equipment similar to yours... http:
I realize a pressure test may not always be required for a PV repair. I was curious about why you were considering one and offering a possible alternate course of action.
It's fundamentally "wrong" to use "air" as your pressure test medium if water can be used, regardless of operating pressure and operating fluid and temperature because of the risk of failure with air.
Water is a non-flamable, non-explosive, incompressible medium when used for hydrostatic testing. That is, if (when!) the vessel or a component fails during the hydrostatic test, the pressure is released due to the leakage through the fitting or failure point. When even a quart or liter (or even a single cup of water) is squirted out, the pressure goes down. So your hydrostatic test is sensitive enough to show you leaks. Your pressure test is safer, since, when a leak happens, the internal pressure goes down quickly.
With air, you may not even notice (be able to display on the gage) the loss of pressure over time since the gas pressure goes down at a negligible value with the same loss of mass. (Water is 1000x as dense as gas.)
So -even if there were no heat energy (your original question was about testing with steam - remember!) - a failing pressure vessel under an air test has a MASSIVE amount of residual energy held inside that will continue the failure. Continue the destruction and danger.
Would I sit on top of pressure vessels I built when I test them? Well, I have sat inside pressure vessels that I have built (technically, submarines that other people have built for me) under their design pressure and temperatures ....
But, it is better to be prudent: If you can test without threatening your safety (Other people's safety) why threaten them and threaten your company? And the Thresher DID fail its pressure test after being built and repaired. As have hundreds of other submarines, all failing under various excessive pressures and shocks.
I don't believe anyone suggested testing a new PV with steam. Testing and examination for repairs and alterations of "in-service" (not new) ASME Sect I, IV, & VIII boilers and pressure vessels is governed under The NBIC Part 3 Sect 4. The type of testing and examination chosen will vary depending on the nature of the repair or alteration.
Cheers,
gr2vessels
Is a paper machine roll truly a pressure vessel in the sense of Sec VIII or otherwise? Does it have an ASME (or PED) name plate and/or NB number?
I have bene around a lot of pressure vessels in paper mills and never considered that the paper machien rolls were one of them. Was I just that blissfully ignorant?
And, what is the design operating pressure? Most paper machine rolls that I have had any experience with (normally with the steam supply or condensate offtake systems) were at or very near atmospheric, and usually no more than 15 psig. But I didn't check them all so I am a learner here. I'd like to know how a pressure vessel can have a shaft down the middle of it or a rotating condensate shoe fitted to the rotation point.
I'd be interested in the details.
rmw
http://
http://ww
On-site hydrostatic test for an existing dryer pressure vessel could be detrimental and dangerous. If a hydro is considered dangerous for this type of equipment, then a pneumatic test would be more hazardous.
Yes these ARE ASME coded pressure vessels (up to 150 PSIG) and testing with steam OR air is accepted where situations dictate by the National Board of pressure vessel inspectors and has been accepted in the past by relevant authorities in other countries besides the States.
The crux of the original question was basically; Does anyone know the difference in the expansion rate (due to difference in compressibility), between air versus saturated steam, if there was a sudden release of pressure through fracture of one of these vessels? Hence, which is more dangerous?
Thanks for everyones input so far! Much appreciated!
Lets say steam is 10 times compressive than air and it can clime up to 10 at the square.there is your answer.
Cheers,
gr2vessels
Use compressed air or nitrogen if water is not even slightly feasable, and stand well away from the vessel during its first test, behind something sturdy.
If you are foolhardy enough to use steam for the initial testing, use remote viewing to run the test. A catastrophic failure is extremely unlikely, but the consequences are HUGE. Plan on all the equipment around the vessel being destroyed, and every person near the vessel dead, or dying from 3rd-degree burns.
Hydroing with steam is like walking a 6-inch wide beam 100-ft / 30m in the air. You will almost alyways be OK doing it. Almost.
But the consequences of a failure tend to be unacceptable.
It is similar if asking people: Do you prefer dying from steam explosion of air explosion?
Rapidly expanded 150# steam is still steam.
Gos 'boom' w/air - if the shrapnel misses you, you're OK
Gos 'BOOM' w/steam, due to better expansion energy of entrained condensate flashing off, the shrapnel will be a little more energetic. And you get the pleasure of 2nd-degree burns over your body.
If I'm not smart enough to figure a way to use water, I'll take air or nitrogen, please.
In terms of an exploding pressure vessel with saturated steam I would expect the vessels shell to initially explode and be thrown apart in a similar way to an air explosion. But then the steam would very quickly condense when it hits the cool atmosphere, so there would be a reduced pressure wave.
Testing an old vessel with steam just sounds crazy. The cost of the setup. All that extra safety hazard analysis. How do you get steady state conditions to assess the result of the test?
Pneumatic test for your vessel sounds crazy as well. If it has an operating contents of steam then surely it can be hydrotested.
I work in cryogenics. We only Pneumatically test vessels that we can't completely dry out because the tiniest traces of ice can be catastrophic.
As for the energy stored in Steam vs Air. That is a no brainer.
We have had tires explode and send pieces through concrete barriers. What happens if one of your rolls explodes violently?
