Portable DewPoint Meter
Hello All,
Our plant is in need of a protable dewpoint meter to verify we are purging the new equipment to -40C.
The purge gas is nitrogen, pressure 0.5 - 10 barg
I have seen them before. Sample gas in and then a sample gas out. Plastic tubing was used to connect the inlet gas feed. I don't remeber the brand that I saw.
Does anyone know of a good brand or a place to locate one?
Thanks in Advance!
Ken
Thanks in Advance!
Ken
RE: Portable DewPoint Meter
Usually, dewpoints that low are tough to measure without a chilled mirror device.
Check GE Sensing or Vaisala. ge-mcs.com or vaisala.com Either is good on the phone to help select a model.
Good on ya,
Goober Dave
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
hope this helps. Good luck!
-pmover
I see GE has swallowed up Panametrics.
Aluminum oxide / gold sensor dew point meter http:
Richard www.6sproductivitycom.com
