Point load on existing slab
Could anyone suggest me how to check existing conc. floor slab if the point load on mezzanine column around 4000 kg. as my attached file,or concept to solve this problem,I'm a fresh graduated civil engineer?
- the customer have the existing concrete slab as the details below:
- slab L.L. around 500 ksm.
- slab on beam
- factory
Thank you
- slab on beam
- factory
Thank you
RE: Point load on existing slab
Essentially you resource to the codes to check if the standing situation won't need any change to reinstate the safety demanded in them. This is worth to mention because you may find in the literature experimental (and so amenable technically) info on the strength of things that may vastly exceed the capacity as stated by the codes; using this kind of resources may be useful when the code allows somewhat for alternative designs (that many do, one way or another) but it is important to acknowledge that the standing standard of safety is just portraited by the currently vigent codes.
http
