ETABS nonlinear dynamic analysis
Hello, I'm Henry from Philippines
I'm currently working on a project and i have to evaluate the seismic performance of my structures.
I placed nonlinear hinges on my model and run a time history analysis.
my problem is that ETABS does not recognize the nonlinear hinges i placed. the hinges does not appear to have an effect on the result of the displacement due to the earthquake.
does etabs evaluate failure due to dynamic earthquake loading?
RE: ETABS nonlinear dynamic analysis
However, ETABS does activate the "link" element during nonlinear time history analysis. The way I have modeled this in the past is to use the link element to model bilinear nonlinear behavior, meaning you can model a linear region and then a plastic region. I do not believe you can model a failure mechanism using this element as it is limited to bilinear. However, for the retrofit I have done in the past using ETABS we were shooting for immediate occupancy therefore our performance point was well before failure would occur and this element was therefore satisfactory.
