Maximum stress node number
how to get node number with maximum stress in ANSYS 13 workbench ??
RE: Maximum stress node number
Hi all,
I have a (kind of) similar question : how to display node numbers in workbench (mechanical)? (it was a habit to display it when i was using Abaqus)
In 13 you can export results in the Solution Tab.  Just pick max stress criteria to the part, right click -> Export.  Then in Excel you can sort the rows on your stress criteria to find the node number.  Use the max and min toggles to find the location.
