Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I train people in ACCESS. I make sure they know about these forums, give them some training on how to use the site, and have a shortcut to it on their PC's..."
Geography
Searching points within a bounding circle in excelHelpful Member!(2)
waughe (Petroleum)
25 Nov 11 23:24
I am trying to find points in an excel database that lie within a circle with a 50 mile radius.  I have over 100,000 points in the database all given in lat/long form.  The center of the circle will be lat/long (x,y).  How do I write a macro that finds the points bounded by this formula?
cloa (Petroleum)
5 Dec 11 20:45
Better to post in the Engineering spreadsheets subforum
http://www.eng-tips.com/threadminder.cfm?pid=770
Helpful Member!  MortenA (Petroleum)
6 Dec 11 8:09
Your database contains a lot of points (referencea) with data in the lat/long form - and you want to select those where the distance to another reference point is less than X miles?
First make sure that your coordinates uses the same units as your criteria. Then use pythagoras to calulate the distance then select if<X.
You dont even need a macro. Just add the calculation in the next collum and use conditional formatting to highlight the matching points. If you wish to remove all non match, then write a macro, do the calc and erase all the non match. Use "record macro" to quickly determine the coding for navigation and deleting a row.
Best regards
Morten
Helpful Member!  DRMABZ (Geotechnical)
7 Dec 11 9:48
Just to add to the very good suggestion.
You can rap your distance calculation into an "if" function and have it return 0 or a 1 e.g. =1 if within your distance (circle). You can then use the filter function to produce a list, which if required could be copied into another sheet. The filter function will be very useful for large non-sequential lists.
Close Box
Join Eng-Tips® Today!
Join Us             Close
