Can anyone tell me what this is?
I was given some pictures of an item and was asked if I could find out what it was. After a lot of searching online, I still haven't nailed it down. Can anyone tell me what this is? Sorry about the picture quality, it is a picture of a picture.
RE: Can anyone tell me what this is?
I suggest you Google it for an explanation.
Marmite
The lower right is a KWHr meter such as is used on your home. This one will be rated at 120V and 5A rather than 240V and 100A or 200 A for the house meter.
The lower left is similar but records KVAHrs.
The upper left probably records KVARHrs.
The strip recorder on the bottom right probably records KVA demand and may record other parameters also.
With a multiplier of 1600 this would meter an apparent maximum flow of just under 1 MVA. (960 KVA)
Bill
"Why not the best?"
Jimmy Carter
rasevskii
No oscilloscope, no serial port, no firmware upgrades, no latest revision of the setup software.
Okay... post-Thanksgiving nostalgia...
old field guy
http:/
You mean decades.
Indeed. Amazing..
Keith Cress
