Element and connection Capacity/Demand Check
I'm hoping to get SAP to check the Capacity/Demand ratio (get SAP to highlight the failing elements and connections in my structure). I understand that the design function is able to check for and highlight the failing member.
I'm just hoping to find out if there is a way of checking for failing members. How would I enter the Capacity of my members and connections if SAP is capable of checking for failing elements and connections? I'm using a general material (Wood).
Thanks in advance!
Thanks in advance!
RE: Element and connection Capacity/Demand Check
