Material Properties
Material Properties
Material Properties
I'm using Autoform for FEA on forming sheet metal parts. My problem is that to accurately produce results in the software, I need to specify information regarding the material. I have all of the material specifications including composition, yield and tensile strengths and r/n values. I am trying to create the material for 436L stainless steel. Please find attached my material properties and a menu from Autoform that I need to add the information to. I'm not a metalurgist so I'm not sure what all the symbols meen. Unfortuanately the only way for me to obtain correct R0, r45 and R90 values is to test a material sample. But at this point I'm only working on this analysis from a feasability standpoint. If anyone could offer me some insight on what to fill in the menu from the properties, it would be greatly appreciated.
Rob
RE: Material Properties
You forgot to add the "menu from Autoform that I need to add the information to."
How about using average strain ratio, 1.3 for this case, for all three directions? This seems a fairly good start to me on the condition of no access to real testing and still including thinning effect, non-unity strain ratio.
Try to be a bit more specific in the title.
