Sketch visualisation smoothness
Hi.... I forgot how to change or set the sketch visualisation smoothness.
As it is by default, it s ok, but with some big zooms, circles get very faceted, instead of smooth and circular, you actually see line steps.
Preferences/visualizaion, apparently only work for shading in main viewport for surfaces.
So, how can i improve the display quality of lines in sketches?
Thank you
RE: Sketch visualisation smoothness
Thank you for replying.
Maybe i did not make myself too clear, sorry.
What i am looking for is for a preferences setting that determines the tesselation of sketch lines. Similar to how we can do for surfaces in preferences/visualisation/faceting.
Hitting refresh doesnt change anything really.
A circle looks pretty jaggy to me, a bit "pologonised"... I d rather see it as a smooth line.
So the question really is if there is any setting that determines how the sketch lines are tesselated. If it is automatic and the software decides , that s fine, just asking.... i dont know. I can determine if lines look smoother or coarser in catia and solidworks... Similar setting for nx too?
Thanks again:)
What NX version are you running ?
 In older NX versions one had to "Update Display" quite frequently.
 Then I also used to change the Preferences - Visualization - Line - Curve Tolerance to a finer value.  But I never touch that value anymore since it seems to automaticly update the smoothness.
Look in preferences -> visualization performance and turn on the line antialiasing.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, Beta NX8.0.0.25
