Head over an adjustable weir
Hi Folks,
What is best instrument (sensor) that can be used to measure the head over an adjustable sharp crested weir?
I am not sure whether this is the correct forum.
Thanks is advance.
RE: Head over an adjustable weir
cvg,
My intention is to use two adjustable weirs to distribute (will not necessary be equal) sewage plant influent to two clarifiers. Weir controlling will be done remotely by monitoring head over the weirs through 4-20 ma signals. The head over the weirs can vary depending on the influent, and, the flow desired to be sent to each clarifier. Under these conditions, unlike in a fixed wier scenario, the head over the weirs can vary. Is it still possible to use a US sensor? If so what is the best way to calibrate the sensor?
