Ballast at grade crossing
We have encountered a small problem,
Is the necessity for ballast use is to drain the water, because if so, this mean we could use finer grade and compacted rock at a grade crossing because water just flow ON the road and never gets into the ballast at this section...
Tell me if I'm wrong
RE: Ballast at grade crossing
Biggest problem at grade crossings is the corroding feet of the rails. You'll need to provide a solution for this.
