get user input
get user input
get user input
Code:
Dim initial As String = "enter name"
Public Sub dialogShown_cb()
Try
  string0.GetProperties.SetString("Value", initial)
  string01.GetProperties.SetString("Value", "")
End Try
End Sub
Public Function apply_cb() As Integer
Try
Dim UserInputString As String
  UserInputString = string0.GetProperties.GetString(initial)
  string01.GetProperties.SetString("Value", UserInputString)
End Try
End Function
Error: Invalid property name for the block... .GetString(String propertyName)at appy_cb()...
Anybody knows what's wrong with the above code? I'm guessing is something simple but I can't see what it is!
RE: get user input
Instead of in the apply_cb function use the update_cb function which needs to be
Public Function update_cb(ByVal block As NXOpen.BlockStyler.UIBlock) As Integer
  Try
    If block Is string0 Then
      UserInputString = string0.GetProperties.GetString("Value")
      string0.GetProperties.SetString("Value", "Enter Name")
    ElseIf block Is string01 Then
      '---- Enter your code here -----
  End If
 Catch ex As Exception
 End Try
 update_cb = 0
End Function
Hope this helps
Frank Swinkels
RE: get user input
Thank you!
Can I further ask if you know the attribute for making the string visible/hidden?
I was looking to find the state of the string and change it.. but nothing similar appears in the library.
RE: get user input
There is a show method which for say string0 is
string01.GetProperties.SetLogical("Show", False)
This would hide all string01.  Simply use
string01.GetProperties.SetLogical("Show", True)
to again show it.
Is this what you were looking for?
Frank Swinkels
