how to apply a point load on a curve?
hi,
let's say i have a rectangular surface, I'm trying to apply a downward point force at 4mm of curve(10mm). Do i create a point at the 4mm and associate the point to the curve(that's what i'm thinking but its not working) then apply the force on the point?
RE: how to apply a point load on a curve?
Hi, wei123
For example, create surface , create point , associate point to surface, Apply load and constraint, create material , create material properties use 2d solid and plain strain, Then Analyze.
That's it.
Hello char, thanks I have solved the problem.
