Model for the beam
Model for the beam
Dear people,
Can somebody attach file of the beam which is working in modal analysis. I used beam node 182, solid and all types and nothing, The example of wing in help is already done with geometric properties and it is different if I want to take into consideration beam. I have a problem to extrude already meshed area, or if choose solid, it is impossible to set thickness in real constants. Is it so difficult for work? I just need beam with frequencies to see that it is working.
