Creating a new drawing layout template
I'm in the process of designing a new template for GA/Assembly/Engineering drawings.
I've read BS 8888, but in terms of the actual drawing layout, it's not much use.
Basically, I'm after a British version of this: h ttp://mscw eb.gsfc.na sa.gov/543 web/files/ GSFC-X-673 -64-1F.pdf
RE: Creating a new drawing layout template
Did you try this:
htt
We're using Autodesk Inventor. We have a template already, but I want to make sure it matches up to spec.
Ben Loosli
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
