Tool path width
Tool path width
Tool path width
Hi, i have problem with toolpath width.
If i have in vizualization preferences - line - show width enable, toolpath is thick (see picture), this is opaque.
If disable "show width", toolpath is ok but line is drafting is all thin. What is the solution.
(NX 4.4.0.2 MP10)
Thank you.
RE: Tool path width
No idea?
NX 4.4.0.2 MP10
RE: Tool path width
Can you please re formulate the question, i don't understand the problem. Do you want to display the toolpath in a drawing view ?
RE: Tool path width
No in drawing, i like toolpath with - thin line, default is thick.
If disable "show widths" in visualization preferences - toolpath is thin, but all line in drawing is thin.
NX 4.4.0.2 MP10
RE: Tool path width
It is one (1) switch, on or off, to display the width or not. This applies to all "wireframe" display.
  The workaround is to display Drawings monochrome, then you get a separate control to display drawings "with width" while others is "without width display".
 Preferences - Visualization - Color - Drawing part settings - Monochrome Display - Show width.
- Only in monochrome mode.
RE: Tool path width
I use a black background and colorful entity. Monochrome display is not transparent for me.
NX 4.4.0.2 MP10
