solidworks 'no loads are applied' error
usnig solidworks 2010. when i restrain a face and apply a force onto that face, i get an error that 'no loads are applied to the model'
could somebody shed some light on this?
RE: solidworks 'no loads are applied' error
make a try placing the restrain or the loads in a different position
works now?
don't like signature that much
Kd=0
where you know K (the element stiffness) and d (nodal displacement) will then be zero.
Of course if not all directions on the face, edge or vertex are constrained then if the force is in an unconstrained direction you should be able to proceed.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
