AWD Pushrod front suspension design
Hey Everyone,
So I have tried to do some searching but haven't come up with concrete information. My only current book is Chassis Engineering by Herb Adams which is no help in this question.
I wanted to ask people with first hand knowledge of this. I am looking to build an AWD tube chassis super car and for packaging purposes I believe a pushrod design will be necessary. Unfortunately there are not a lot of real world examples I can use to copy.
I was looking at the Aventador suspension for inspiration and I was wondering does the angle of the pushrod matter as long as the bellcrank is at the same angle as well?
It seems the ideal(common) design has the push rod originating from the center of the lower control arm at an angle to pass the axle up to the bell crank. I was thinking why not use a pushrod that is offset either to the left or right side of the control arm so the pushrod is moving 100% vertical with the suspension. I assume this is because a torque would be caused about the axle centerline if you have it offset? Or is it some other issue?
I have seen rear pushrod setups with offset rods but they also have lateral links and the upright does not turn.
Is it also not possible to mount the pushrod to the top control arm to transmit the movement? What is the issue with doing this? Clearly there must be a disadvantage for people to avoid it.
Lastly, what type of connection would you recommend for the pushrod ends? A Heim joint?
Sorry for all the questions I just don't see a lot of examples of this and figured this would be the best place to ask.
thanks for the help! Any other suggestions would be greatly appreciated.
reference images I have found:
32 hot rod
Aventador:
full link to lambo setup: ht tp://blogs .insidelin e.com/stra ightline/2 011/09/201 2-lamborgh ini-aventa dor-suspen sion-walka round.html
Ben
32 hot rod
Aventador:
Ben
RE: AWD Pushrod front suspension design
There was a variation of pullrod mechanism in early '70ies*- a bit earlier than, in my knowledge, 'proper' pushrod/pullrod linkages were used, designed by Len Terry in order to get a progressive spring characteristic. I think he might have designed it as an improvement of rather complex progressive rate system one of McLaren F1 cars used in '71... It didn't use bellcrank as one would expect, so I'll attach a picture in case it's of any interest.
In terms of the terminology I still don't understand how the setup on the Zonda would be a pull rod setup. Unless in this situation the control arm is technically the "pushrod" and they don't count that...
Is there an issue in terms of motion? As in would this be less than a 1:1 ratio? I would assume it would be very slightly less than 1:1 if you had unequal A arms. Would this cause a potential issue and if it is can a 1:1 ratio be re-captured with the right bell crank geometry?
thanks again for the help this is giving me great design ideas.
Ben
Cheers
Greg Locock
I assume you want to avoid a situation where you say only have half the motion of the wheel translated to the suspension otherwise you need twice the spring rate/damping ability?
thanks for the help and input!
Ben
Norm
thanks
Ben
Cheers
Greg Locock
I think I like the design and simplicity of the Pagani upper control arm design as it was close to what I originally envisioned but wondered why more people did not utilize it like on the Aventador if it was a viable solution.
thanks again for the help, this will be a long project but it will be fun.
Ben
