make a copy into a separate part
What is an easy way to change a part (that was copied from a part in an assy) into a new separate part?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: make a copy into a separate part
Chris
SolidWorks 10 SP5.0
ctopher's home
SolidWorks Legion
If the assy is open, and witht he copied part open in it's own window,use the Save as function, but be sure to select the Copy option.
After saving, return to the assy and use the Replace Components with the All Instances option NOT selected, to switch the copied part to the newly saved part.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
