Using Aluminum Windinsg in Outdoor Distribution Transformer
We received a bid to install aluminum windings on a 11kV primary - 480 secndary 2MVA transformer installed outdoors. Winter weather can be harsh - down to -20F.
I am assuming the cold weather won't be a problem because the windings will be heated thorugh it's own losses and warm the insulating oil. Is that a correct assumption?
Thanks.
c
RE: Using Aluminum Windinsg in Outdoor Distribution Transformer
I'm not aware that aluminum windings have any particular limitation regarding cold weather.  Efficiency is the main concern.  Most step-type voltage regulators used on distribution feeders have aluminum windings, at least in my experience.
Pole mounted transformers in Quebec, Canada have aluminum windings and are designed to operate at such a cold temperature.I suspect the same for pads.
