How to Request Improvements or Enhancements
Hola!
So there seems to be no easy way to generate a dogleg when performing a simple dimension (ex. showing .010" remains on a face after turning), without using ordinate dimensioning.
If I want to add this to Siemens list of enhancement requests, how would I do so? It's not an "incident", so I don't think I should generate a report. ponder
RE: How to Request Improvements or Enhancements
edit dimension style the line arrow tab the parameter F
hope it helps
When you open your incident with GTAC, tell them it is for an enahncement request and provide them the details of what you need.
Everything starts as an incident and then procedes through the system on different tracks.
Ben Loosli
You can also open an 'Incident Report' right from within your session of NX.  Just go to...
Help -> Online Technical Support -> Log an Incident with Technical Support
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
I received this ER template from GTAC...
What activity in your process is NX not able to currently handle?
What result are you trying to achieve?
Do you currently have a workaround?
Do you have a proposal for the solution you envision NX providing for this capability?
What is the level of productivity gained from such an enhancement?
NX 7.5
