copy sketches in part
can someone tell me if there is a way to copy a skech or an extrude in part design other then using the miror option?
i like to copy a sketch to other place in the same part for cutting, but the new location doesn't fit to do it by miror.
RE: copy sketches in part
The way to copy?
Just select the sketch you want to copy in the feature manager,then press <ctrl><c>. After this select a plane or a face you want the sketch to be copied to and select the "sketch"button. Now you press <ctrl><v>, and there it is: the copy of your sketch.
When inserting dimensions again, do this right away, and start with the element sizes, since all these are still the right size. After this, add the dimensions needed for the positioning of the sketch.
You can also copy a feature by CTRL+drag the feature to its new location (can be a different face, even a different part (must be opened, of course))
Thanks, this is vital information for optimizing my method of working,
Aart
Crashj Johnson
