Internal error NX8
Internal error NX8
Friends
Actually I am working with a solid part and when I select "Assing Material" the sofware launch a message "Internal error: memory acces violation".
I restarted the Pc and the problem still appears.
Some one of you know how can I solve this problem?.
Thanks a lot for your time and tips
Tom
Tom
NX 8.0.0.25
RE: Internal error NX8
Just so we're all singing from the same hymnal, have you edited or modified your material library file(s) in any manner? Perhaps using an older material file which was modified for an earlier version fo NX?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I assigned prevously a material in my model, but today it doesn´t work when I tried to change it.
Let me check with PLM support in my country
Best regards
Tom
NX 8.0.0.25
I have the same problem as you described.
Best regards
Ben
NX 8.0.0.25
Are you using a non English version of windows?
An update to NX8.0.1 will solve the problem.
You will have the same problem with the Reuse Library.
This is not the fist time Siemens has messed up with non English version of windows.
Mattias
NX5, NX6, NX7.5 and NX8
I-deas 12, NX I-deas6.1m1
Solid Works 2009
Last week i added a new material to our library and made the mistake to have spaces in the material name, "internal error" . It will also crash if you leave the density value blank on a material.
We are still running the "legacy" material library in NX7.5 since most our materials have been setup in older NX versions.
Make sure that (check the NX syslog) the variables containing the string
"PHYS_MATERIAL" ( without " ) all point to a directory where the files :
"phys_material.dat"
"phys_material.tcl"
exists.
These files exists per default in \nx install directory\ugii\materials\
If you ave modified them, replace the edited with the ootb files and see if you still have the crash.
I checked this item with my PLM and results that the problem was because I had Windows XP, I Only changed the platform to Windows 7 64 bit and the problem is gone.
Best regards
Tom
NX 8.0.0.25 64bit
Yes, I have non English Win XP
I will install it in new computer.
Ben
