Macro - count number of fasteners
I'm trying to wrtie a marco to count the number of fasteners within a single CATIA part. More specifically, I want to count the number of spot welds but I'm not sure what the best approach is. Any ideas on how to get the number of spot welds?
Here's what I have so far:
Dim partDocument As PartDocument
Dim Part As Part
Dim oSpotWeld As SpotWeld
Dim i, oSpotweldCount As Integer
Set partDocument=CATIA.ActiveDocument
Set Part = partDocument.Part
Than I assume something along the lines of spotweld.count?
http://excelspreadsheetshelp.blogspot.com
RE: Macro - count number of fasteners
Can you post a sample part ? Question is how the fasteners are represented ? Lines with a specific length or color or something else ?
Fernando
All of the spot welds have a point at their center called "WELD_CENTER_PT" as well as a line projected normal to the mating parts called "WELD_LN".
You didn't specify where are those points, so bellow is an example how this can be handle (of course you have to modify the CATScript).
I would search for the name "WELD_CENTER_PT" to create the selection.
Language="VBSCRIPT"
' The goal of this macro is to illustrate the use of the following methods
' on CATIASelection: SelectElement2, Count, Item
Sub CATMain()
  'Definition of a list of types for objects
    Dim listOfTypes(1)
    listOfTypes(0)="Body"
  listOfTypes(1)="Hole"
    Dim myDocument
    Set myDocument = CATIA.ActiveDocument
    Dim mySelection As Selection
    Set mySelection = myDocument.Selection
  'If the selection does not contain any Body or Hole, then the following message
  'appears in the bottom left corner of the application, and the script execution
  'resumes as soon as a correct object has been selected.
  'The SelectElement2 method fills the selection with SelectedElement objects whose Value property is of the
  'specified type, as mentionned in the listOfTypes list.
    Dim str As String
    str=mySelection.SelectElement2(listOfTypes,"Select a Body or a Hole",true)
  'Computes the number of Bodies or Holes that have been selected
    Dim number
    number = mySelection.Count
  msgbox "Number of Bodies and Holes selected: " & Cstr(number)
  'Since there is no more temporary set of objects, the Count and Item methods apply
  'to the whole selection.
  msgbox "Total number of objects in the selection: " & Cstr(number)
  'Now, we retrieve each object from the selection
    Dim selectedElement As SelectedElement
    for i=1 to number
    Set selectedElement = mySelection.Item(i)
    msgbox "Object " & Cstr(i) & "/" & Cstr(number) & "retrieved."
    next
End Sub
Fernando
I created a new macro to count the number of weld points in my catpart. I use selection and search to find the weld center points and axis lines. Some of the code is below:
Dim oSelection as Selection
    Set oSelection = CATIA.ActiveDocument.Selection
    Dim iCount
    Dim i
    ' search for center points
    oSelection.Search "Name=WELD_CENTER_PT,all"
    iCount = oSelection.Count
msgbox "Number of weld points is "&icount
    ' save points in array
    Dim aPoints()
    ReDim aPoints(iCount)
    For i=1 to iCount
        Set aPoints(i) = oSelection.Item(i).Value
    Next
    ' search for lines
    oSelection.Search "Name=WELD_N*,all"
'msgbox "number of lines is "&icount
    ' save lines in array
    Dim aLines()
    ReDim aLines(iCount)
http://excelspreadsheetshelp.blogspot.com - http://scripting4v5.com
