hard and stiff material that is moldable
Hi there,
I am looking for a strong and hard polymer that is moldable. The material is expect to be able to cut into (with some pressure) soft polymer such as nylon. It need to have high strength and stiffness to avoid brittleness break.
I was thinking of PPS, PEEK and fiber reinforced nylon. Any comments, suggestions are appreciated.
Gao
Gao
RE: hard and stiff material that is moldable
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
We are currently using unfilled nylon in our product where strength and elongation are two critical factors. To re-design the product we want to keep the nylon portion to keep the mechanical properties. We need another part that can bite into nylon and hold it at some strength (higher strength than the nylon part). For the hard material, the strength (tensile, flexural, and impact)and hardness are the main thoughts right now. Since it need to hold the nylon part, we hope it will not break brittlely as hard material sometimes does. (seems like steel could work, but we want to use polymers) And after all, the hard polymer need to be able be molded without too much trouble.
Gao
Also there are quite a few types of nylon with quite a few grades of each type. Moisture content of the nylon makes a huge difference. This moisture is normally absorbed from the air.
Pat
for site rules
In product operation, the load (shear+tensile) will be applied to the parts for the bite and, when the hard part bite into the PA66, it become static load that the part will keep holding. The application load will involve the geometry of the part, which based on experience, is a combination of tensile, shear and flextural, with tensile strength be the most criticle one. There is no other type of load applications.
Thanks, -Gao
Even acetal homopolymer might do the job at std ambient indoors.
Creep may be an issue, but if the clamp force is maintained, the cutting 9I presume for grip) will get deeper with time. The sharp edge will also dull with time under load, simply from creep.
Pat
for site rules
When you say the cutting will get deeper with time, does that because the creeping of the softer nylon?
Could you comment on the cutting performance of acetal homopolymer, unfilled PPS, filled PA66 (30%) and unfilled PEEK? What are the parameters that determines a better cutting? hardness? modulus? brittleness? Thanks, -Gao
Both parts will creep, but for non cross-linked thermoplastics, the softer one will tend to creep more.
From memory, acetal is about the same performance as 15% GF nylon 6.6 conditioned to std temperature and humidity.
Pat
for site rules
