[drawing/detailing] line width of spline delimiting local section
Hi everyone!
My current issue with Creo/elements is the following: when I make a local section that is contoured by some edges and a spline, the spline shows with the same width as for geometry (0.5 mm).
This is logic, because it becomes an edge itself, but I'm working in ISO standard and it should be shown as a thin line (0.18 mm, 0.25 would be acceptable too).
There is no way to change that line width. I cannot edit it with line style, because cannot select it (either in sketch, annotate, etc.)
I had a look to drawing options and there is no item to change for it.
Hope I explained it clear, and s.b. helps.
RE: [drawing/detailing] line width of spline delimiting local section
line_style_standard std_iso
It did the trick. I regarded line weight and colour as indipendent features, linked just by defaults or custom settings
Anyway, if anyone from PTC is tuned, It's time to unrelate the "forced in blue" text color from the line_standard, isn't it? We users can switch when needed (as I will do from now on), but that blue text is so annoying!
