Need for Load Control Module when paralleling generator with utility?
On a project that I am working on, the client is requesting to be able to test the generator when it is paralleled with the utility (testing up to 80-100% of the output power).
Do I really need to have a Load Control Module to be able to test the generator up to 80-100% of the output power?
RE: Need for Load Control Module when paralleling generator with utility?
With 3% droop, a no load setting of 61.8Hz will give 100% loading at 60 Hz.
Oce you are synchronized, raise your speed setting and the speed won't change but the unit will pick up the load.
Bill
"Why not the best?"
Jimmy Carter
