Generic modeling question
Running NX 7.5 with teamcenter integration. I have a question regarding the modeling of metric holes.
Is there a standard out there that dictates or suggests whether we should model to the nominal or the basic size?
For example, when modeling a 12mm hole with G7 tolerance the basic size is 12mm but nominal is 12.015mm
The reason I ask is because we have been modeling to the basic size and machine shops have been complaining because they like to cut to the model. I would like to respond with "you need to look at the toleranced drawing" and also reference some sort of standard.
On the flip size, you guys might come back with a standard that is contradictory to our modeling practice :)
RE: Generic modeling question
On the Hole Feature dialog you have the option of creating a Hole based on several different criteria including creating a 'Screw Clearance Hole' where you select size of the screw and then based on the tolerance selected, the actual diameter of the hole will be determined by the system.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Your 12mm g7 hole if being drilled or reamed, I would model at 12 since the NC programmer would be specifying the tool callout and the NC program only cares about the center point dimension.
Ben Loosli
Today we are modeling to the basic size but with no fit tolerance in the model. Is there a way to add the fit tolerance to the model and are there any industry standards that I can reference?
Thanks!
My questions are related to modeling (not drafting). If modeling to the basic dimension is the way to go, can this be support by any industry standard? We are designing machines/fixtures/mechanisms for what it's worth...
Not sure why you need a standard to define how to create a model of your own design. Design intent and form, fit and function to your application shouyld be the drivers.
Basic dimensioning is just that, drawing related dimensioning to convey the design intent to others through a 2D drawing. Weather a hole is dimensioned with GD&T basic location or +/- location doesn't change the intent of the design.
Ben Loosli
It does change how the shop handles it.
If you need something lasered and you can provide a dxf to your suppliers, you may have less trouble if they don't have to adjust every single hole in it to make it fit it's specific tolerance.
Having worked as a laser programmer, I can, unfortunately for me at the time, say that most, if not all, drawings came in with nominal drawing, and we had to adjust to the specific tolerance ourselves.
I'm guessing the short answer to dtharrett 's original question is: No, there's no standard
NX 7.5
Teamcenter 8
Ben Loosli
The my preferred practice is to give size limits and then the fit name in parenthesis for reference: 12.024-12.006 (12G7)
That all said, an argument could be made the other way based on the ASME standard:
Models and 2D drawings that are intended for product definition should not be dimensioned in a way that specifies or gives preference to any particular manufacturing method:
ASMEY14.5-2009 1.4(e) : "The drawing should define a part without specifying manufacturing methods."
I don't have a copy of Y14.41 handy but I'm sure the intent there is the same.
If a manufacturer elects to use a particular programming process that depends on the model features being modeled at something other than basic size then it is their responsibility to create a manufacturing model that is appropriate to their methods. This is a manufacturing requirement, not a product definition requirement.
I don't find this second argument particularly convincing or practical but I can see some kind of an opening there to make it. I think that in the majority of situations modeling to something other than the mean just invites confusion and drives costs up.
NX 7.5.4.4, NX 8.0(Evaluating)
Tecnomatix Quality 8.0.1.3
One of the problems here is that some engineers are modeling basic and some are modeling by the mean. Some models have a mix of both. Either way the drawing gets dimensioned the same but the model geometry causes issues for the guys that cut to the model. Obviously we need a standard here.
I was trying to get to an industry standard that we could adopt as our standard here. I have a portion (pages 1-10) of ASME y14.41 but did not see anything however page 11 suposedly has info regarding the model requirements.
Either way, there have been some good arguments for both methods posted here.. Thanks
I just designed a gage the other day for checking the profile of an airfoil shape. It is a simple guillotine-type gage consisting of two plates, each with half of the profile. When the plates are fully closed around the part the part must not contact anywhere on the plates. If you can see light all around it passes. For this to work the plates must be cut to the maximum profile size plus a few .0001's so you can actually see light around a part that is right at MMC. This gage will function best if it is exactly MMC +.0002. MMC +.0001 would be acceptable and MMC +.001 is the high limit. I modeled it at MMC +.0002 because that is really what I want and then applied a +.0008/-.0001 tolerance.
Now the guy running the wire EDM machine probably isn't going to like that very much and is going to want a profile that is right at the mean (median? I think median is probably the better term) so that he can maximize his tolerance. In this case I don't care what he wants. My job is product definition and by modeling that gage as I did I defined my "ideal" product. I will then make a separate file with the profile modeled at the median size for manufacturing purposes if asked for it.
Interesting point(s). I am currious how you would model a 12mm (nominal)dowel and it's corresponding press and slip fit holes. All three features at basic or meadian values?
Dowel: Modeled at .500. Tolerance: +.0003/-.0000. Since this is a standard, purchased component if I were to give the tolerance on the print it would only be in the description field in the BOM.
Press fit hole: Modeled at .500. Tolerance: +/- .0002. This is what a new to slightly used HSS reamer will cut in .4140 PHT under normal conditions. Really this is a transition fit but I know that standard dowels will be +.0002 - +.0003 99% of the time and the reamers we use will cut +/- .0001 of nominal 99% of the time. So 99% of the time I'm going to get .0001-.0004 press, which is what I want, and the tiny percentage of times that I get .0001-.0002 clearance or .0005 press isn't going to hurt anything.
Slip fit hole: Modeled at .5005. Tolerance +/- .0002. This makes it clear that this is intentionally a slip fit hole and should be cut with a .0005 oversize reamer (or bored). 99% of the time I'm going to get .0001-.0004 clearance which is enough to allow assembly and disassembly in a blind hole without venting and still locate accurately enough for most purposes.
