Anchor bolt spacing
Anchor bolt spacing
Anchor bolt spacing
Can anyone please tell me what the minimum spacing between an anchor bolt and the steel reinforcement in a concrete slab should be? Is it dependent on the diameter of the bolt? An ACI reference page would be greatly appreciated. Thank you.
RE: Anchor bolt spacing
There is no spacing requirement between anchor bolts and reinforcing.
