torque rod fuctions
torque rod fuctions
what is the significant fuction of torque rod in suspension system. what load acts on it?
regards
thilak
RE: torque rod fuctions
Without knowing the answer to this lot - a torque rod on a motorbike is used to react the brake torque from a drum brake - I suspect you are after something similar.
Cheers
Greg Locock
I talk about the torque rod at the truck suspension between axle and suspension, on both the sides(LH and RH).
regards
thilak
Cheers
Greg Locock
