Design frame section in SAP2000 section designer
Hi all.
I have the following problem.
I was asked to point out the easiest way to import/design a section in the section designer of SAP2000.
I have the following section (it looks like a C section but it is more complicated) and I was thinking if I can import its characteristics directly with the use of e.g. import an autocad dxf file.
If you cannot see the image download from here:
http:/ /files.eng ineering.c om/getfile .aspx?fold er=ec45505 8-86ae-46e 3-8840-658 4dbb42424& amp;file=S ection.jpg]
Can I do that or should I design it in the designer?
If the latter is the case how can I design the curved parts in the designer?
Sorry but it is the first time that I come across a user defined section. :(
http:/
