corrosion controller
what is FTP air inlet ?
RE: corrosion controller
You really have to provide a context.  I work in Oil & Gas and in my world "FTP" is "Flowing Tubing Pressure".  The title of your thread doesn't seem to provide any clue as to the context since it seems totally disconnected from your post.
David
Sorry is FPT NOT FTP
Okay,
I'm studying the Nalco corrosion stress monitor.
in the instrument, the inlets are:
-Dissolve oxigen sample inlet
- FPT instrument air inlet
The outlets are
-Dissolve oxigen sample outlet
-Dissolve oxigen drain
Do you mean "inputs" instead of "inlets"?
Hmmm.. well when i say "inlets" I mean the pipelines that go to the monitor. and "outlets" the pipelines that come out of the monitor.
for example there is a sample pipeline that go to the DO sample inlet carrin deaerated water.
What I dont understand is the FTP instrument air inlet...
How about  Female Pipe Thread?
