Monotube Damper Without Piston Compression Stack
Interested in the opinion of the experts on the necessity of compression shim stack on the piston of a monotube damper with high speed compression shim stack /adjuster fitted to the remote canister. To my untrained mind it would appear that as the flow of oil displaced by the rod is controlled by the canister compression shim stack, a simple check valve is all that is needed on the piston compression side.
RE: Monotube Damper Without Piston Compression Stack
Having given it more though, I suspect that I have put too much emphasis on the "hi" and should see it more as a mid speed that eventually will blow off to leave the real hi speed compression control to the piston valve. Am I closer to an understanding of the system.
