Allowable stress value of nozzle is less than that of shell.
What to do if allowable stress value of nozzle material is less than that of shell material? I feel it is inappropriate to replace a material of higher allowable stress(shell) with that of a lower allowable stress material(nozzle). Please answer considering the nozzles to be forged saddle type(with lip).
RE: Allowable stress value of nozzle is less than that of shell.
done all the time
just make adjustments in reinforcement calcs
See ASME VIII Div. 1 UG-37 and UG-41
r6155
adilislam123,
             Read the Code as others have done to learn what you need to do. It's all there if you take the time and read the Code.
