to make an opening on a pressure vessel blind f
Dear All
I am dealing with a vertical pressure vessel which its top head is in type of blind flange. During operation we understood that it is better to consider a vent branch on top of vessel. Inside diameter of vessel is about 1000 mm , design pressure is 10 barg and there is no opening on blind flange at this moment.
I want to know can we make an opening hole on mentioned blind flange (say 1/2") to insert a piece pipe/valve for vent branch ?
RE: to make an opening on a pressure vessel blind f
Sure you can do that, but you'll have to satisfy the code and regulation under which the vessel is built.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
Dear Prex
Thank you for your valuable advise.
You need to design the flange...check out Dennis Moss - Procedure 2-9
