Big Piston Rod- What is it off of?
A couple of our bike routes pass by this big piston rod (see photo).  It's been welded to a post, out in front of a farmhouse/ garage type place.  Pardon my bike in front of it, but that'll give you a sense of scale.
So, the $64 question...what is this thing off of?
Note that this is south of Dallas, a couple of hundred miles from navigable water, so it's possible, but unlikely, that it had nautical applications.  Any guesses?
RE: Big Piston Rod- What is it off of?
The big end is surprisingly small.
Why not call in to the place and ask?
Well, in relation to rods I've seen on automotive and diesel applications, this one is very thin for it's length.  Which suggests to me something large, old, slow, and low pressure.
That's too obvious, CorBlimeyLimey.
I did find this statement:
"At pipeline compressor stations, reciprocating engines are used to power reciprocating compressors that move compressed natural gas..."
While it is definitely a Con Rod, it may not be a Piston Rod.
the owner wanted youthful reminders of a long ago occupation . . . not used to keep mail box in place.
trust me, the rod is likely from a diesel or "old" steam steam engine.  there are much larger ones in service . . .
best to ask the property owner.  the owner will be glad you stopped and asked.
although my opinion, i do not think it is from an ICE w/ integral compressor - too small from what i recall.  then again, i have been wrong before . . .
My guess is old steam steam engine.
99 Dodge CTD dually.
It may be from an old marine (Ship) engine.
Like someone already said, go knock on the door and ask.
I think that's a John Deere putt-putt tractor rod
smile
Very very unlikely to be from a marine engine, the big-end is too small in relation to the gudgeon (small-end),although it could well be from a stationary steam (either vertical or horizontal)engine of 1 or 2 cylinder configuration.
Its a connecting rod for between wheels of a steam locomotive. The part in the ground is the link connection to the next axle. The rods have to be articulated to allow the wheels to move up and down.
Too big to be a locomotive wheel con-rod.
I'm thinking something like
I've ridden past this a half-dozen times, but usually, I'm going downhill and hate to stop.  This time I was going uphill, so I made a quick stop for the picture.
Two notes:  The part buried in the ground appeared to be a piece of pipe arc-welded to the rod specifically to mount it.  So I don't think it continued on to anything else.  Also, the big end appeared to have lead/babbit in the bore, don't know if that has any significance as to age or application.  There is not an open business at this location, but some small buildings that are not a normal residence, either- like the guy at some point in the past ran a business on the premises.
The gas compressor engine is sounding the most likely at the moment (either the engine or the compressor).
The biggest clue is south of Dallas.  When I saw the pic I immediately thought oil pumping station due to location.  Mint's got it right in my opinion.  Did you notice any grease fittings?
The links on the pumpjack shown act mainly in tension, so they're quite a bit lighter built than this rod, relative to the length.  This rod appears to be symmetrical, unlike the links on the pump jack.
It's hard to get a sense of scale, but on the pumpjack in the picture, those links are probably around 15' long, too.
This isn't anywhere near the town of West, in McLennan County, is it?  If so, it might be commerating the town of Crush, the site of the famous "Crash at Crush" on September 15, 1896; perhaps one of the larger pieces remaining...
rp
When I was a kid, we occasionally attended pot-luck church dinners held at a community center in Texas City.  There on the grounds was the anchor of one of the ships that exploded.  But I doubt the Crash at Crush was quite that widepread!
looks like it is off an old pump jack, but not a lufkin.
JS...
When are you going to next ride by this thing, and knock on the door?  The suspense is killing me...
My dollar is on an old long-stroke marine oil fired or steam engine.
When Mint Julep said that the big end was surprisingly small, I was thinking that the small end is surprisingly big.........
just shows what I know............nuffink.
Such things are determined by one's personal framework censored
perhaps the big end is the small end and the small end is the big end
