Door Type
Door Type
Door Type
I'm trying to determine the name of an industrial fire rated door.  It is almost archaic and is/was located in some old industrial buildings.
The manner of construction was prescribed and it could provide a 2 hour or more FRR.  It was recognised by one of the Building Codes in Canada, the NFPA or FM Global; I don't recall, now.
It was fabricated from sheet metal material and was often suspended on rollers and overhead channel track, with gravity closure and a metal bracket at the closure end to prevent it from being 'pushed' open and to provide a seal. It sometimes had pulleys and a 'bucket' counterbalance to assist opening.
Can anyone recall the name of this door assembly?
Dik
RE: Door Type
dik...doesn't ring a bell. Have you contacted Warnock Hersey?  They rated most of these doors.
RE: Door Type
I've seen what you describe many times, but can't recall the manufacturer either.
Mike McCann
MMC Engineering
RE: Door Type
I just checked with another oldie... and he thinks they are called Kalamein doors... will chase that down...
Dik
