Stresses on 90 degrees base elbows
A 14 diamter pipe stub is welded all around on a 24" 90 degrees short radius elbow supporting the riser above. Is there a formula or procedure to determine the stresses on the 90 elbow without running FEA, etc.
RE: Stresses on 90 degrees base elbows
