Static gravity component and RAO
Hi - my first question on eng-tips so go easy on me! Currently designing topsides equipment on an FPSO although confused by RAOs and if the calculation includes for the static gravity component due to the shift of equipment COG at the given roll angle. My original thought was that both were independent as the vessel restoring force represents the acceleration and deacceleration but would appreciate some guidance.
RE: Static gravity component and RAO
Its up to you to do the calculation for the static and dynamic components of accelerations as you see fit.
