static FEA problems! anyone can help?
Hi all, i'm actually modeling a cooling tower and i'm facing bugs during FEA analysis. the one which is slowing me down is the "undefined material" error. i have no idea of what that means...
i have some more clues to give:
- material definition is not the problem as i changed my brand new steel to the default one and the problem didn't solve.
- material is defined for every component of the assembly
- the model ran successfully a FEA in the early morning, started giving problems after.
- the meshing runs perfectly for all components, even for those with mesh control.
if someone could spare help or experience sharing would be simply great, actually my solution is to start another study from zero
thanx all
thanx all
RE: static FEA problems! anyone can help?
Certified SolidWorks Professional
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
@kellnerp: the entire assembly with single parts attached is like 80MB and is half italian half english as i put the language pack after i started. don't know how of use it can be, but if u want me to send it it's fine
Italian doesn't bother me, I can figure out technical language pretty quick.
TOP
CSWP, BSSE
Look in options for Simulation. Somewhere there should be an option to export the model.
TOP
CSWP, BSSE
by the way, thanx for your time
Is there an option to export the mesh?
Just looking at this, why not do it as a shell mesh? It would be a lot more efficient and accurate at run time.
TOP
CSWP, BSSE
however, the problem of the material undefined seem to be tied to cylindrical geometry which appears harder to elaborate even if meshed
btw, can't find a way to export the mesh
You will have to pardon me, I don't have the latest versions of Simulation, but what I do have goes back a few years. It may also be that they removed the functionality.
TOP
CSWP, BSSE
simulation file - .geo
ANSYS file - .ans
NASTRAN file - .dat
ABAQUS file - .inp
Patran neutral file - .neu
IDEAS universal file - .unv
Exodus file - .txt
i also got an options regarding offset of nodes, it makes me write 2 numbers.
don't excuse you on anything, you are helping a lot
don't like signature that much
If they ask for node and element offets then why not give it a small number like 10 for both?
Maybe you can do a screen capture of the dialog box (window) and include it here.
TOP
CSWP, BSSE
this assembly is two part composed, the bottom and the body. as they get analyzed well when they are alone, i guess the problem is when they are together as it happens now. so i gotta focus on how they are mated. or maybe i can analyze them individually
TOP
CSWP, BSSE
Try that. Should give a .geo file with node and element specifications.
TOP
CSWP, BSSE
i'll let you have the .geo file asap if u still want it
still thanks for the kindness and the availability of the help
Sorry for misspelling esporta.
TOP
CSWP, BSSE
