Determine PE and Heat Tolerance
Can someone shed some light for me on permeance coefficient (PC) for a specific magnet. We have an application when needs to operate in a fairly warm environment, and I understand that the PE is critical. My understanding is that even though the manufacture has noted the MaxOperationalTemperature of 80C, given the geometry the PE may cause it to be less?
So after doing searching and searching I came across a couple of PE calculators... I'm not sure how they are getting the information but something is not right..
The magnet is a Sintered NdFeB (Grade N52) ring (0.5"OD x 0.1875"ID x 0.0625" Thick) magnetized through thickness.
1) http:// www.intema g.com/calc ulators/Pe rmeance_Co efficient_ Calcs.html
(Yeild a PE answer of 0.354)
2) http: //www.magn etsales.co m/Design/C alc_filles /Permeance Coefficien t-Ring.asp
(Yeilds a PE answer of 0.35)
These both jive so I assume this is a correct value.
The manufacture has provided two charts...
a) BH Graph (See file below)
http:// files.engi neering.co m/getfile. aspx?folde r=75f18df8 -d169-4250 -aae4-7b75 c33c7c05&a mp;file=BH -Graph.pdf
b) Demagnetization Chart (see file below)
http://fi les.engine ering.com/ getfile.as px?folder= e2e5e53c-8 69f-483b-b 9fa-ad0fd1 9b9829& ;file=Dema gChart.pdf
Questions:
1) These websites seem to be calculating the PC using some type of formula. What is the formula?
Obviously it is only dependant on the shape.
2) It was my understanding that the PC could also be derivied from the BH graph as PC=Hd/Bd (correct?)
By looking at the graph though that would put the PC at about .925, which isn't close to 0.35
3) Should the BH graph change for different size magnets of the same material/grade?
4) How do I read the Demag chart to determine the max temperature. The stated Max Temperature is 80C, but we have tried the magnet and it fails far below that. Its above the knee at 20C and below the knee at 50C.. but I can't image it wouldn't take 50C.. Am I missing something?
Obviously I'm making some wrong assumptions here, but I can't figure it out.
Paul
1) http://
2) http:
http://
http://fi
Questions:
Paul
RE: Determine PE and Heat Tolerance
Cheers!
Paul
There are grades of Neo RE magnets that have a straight line demag curve at 80 C. Look at the Magnetics website.
see attached. .
I think this link should help you. . .
http://www.shinetsu-rare-earth-magnet.jp/e/design/
