center of a surface or a body?
Hello
How can I get the center of a body or a surface?
RE: center of a surface or a body?
What do you mean "get"?  You can find the center of mass with the mass properties dialog.  The coordinates will be relative to your coordinate system.
Dan
www.eltronresearch.com
Dan's Blog
Hi
I mean not just to get the number but automatically draw a point in that place
A surface has no mass, so a CoG will not exist. However, a Reference Point from the Reference Geometry toolbar can be applied to it's centre of area.
Tools/Mass properties gives the centroid and moments of inertia for a solid.
Tools/Section properties gives the centroid and moments of inertia of a planar surface.
I suppose if you wanted the centroid of a non-planar surface you could thicken it by a very small amount and use Mass properties.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
You can also get the centroid of a surface/face by inserting a reference point.
INSERT/REFERENCE GEOMETRY/POINT
check the center of surface option.
select the face or surface you wish.
Jon
